Date/Time: Sun, 28 Apr 2024 19:06:03 +0000
COLUMNS WITH NO DATA
View Count: 2416
[2013-03-22 18:24:18] |
User57072 - Posts: 49 |
I AM ASKING THIS AS A NEW MESSAGE CAUSE I HAD ATTACHMENT TO SHOW. I APOLOGIZE FOR DUPLICATE QUESTION. HOW CAN I HAVE CHART SET TO SHOW COLUMNS WITH NO DATA? I HAVE ATTACHED A SETTING I THOUGHT WOULD DO THIS. HAVE I DONE SOMETHING WRONG ? |
SEND TO SIERRA CHARTS.png / V - Attached On 2013-03-22 18:23:56 UTC - Size: 53.55 KB - 769 views |
[2013-03-22 18:57:15] |
We need to make a correction to what we said previously, this is supported and you have the correct option enabled (Include Columns With No Data). So what exactly is the problem? Saturdays and Sundays are excluded and will not be included in the chart even with this option on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-22 19:28:14] |
THE CHART DOES NOT SHOW A COLUMN WITHOUT DATA. IT IS DOES NOT SHOW HOLIDAYS. Even with the " Include columns with no data " selected, i am still unable to get holidays to show as an empty column. Can you help me ? Date Time Of Last Edit: 2013-03-23 15:19:38
[2013-03-26 13:43:11] |
Hello I just downloaded the latest version of Sierra Charts. I am still unable to show columns with no data. The holidays are not showing up as columns with no data. The box " include columns with no data" was checked. Please help with this. Thank You Rick |
[2013-03-27 00:29:32] |
We need a clear example of this. Please provide a chart by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image And let us know what date is the holiday that you do not see. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-27 01:44:28] |
http://www.sierrachart.com/image.php?l=1364347261623.png I only worked on the first 3 months i don't no about the rest of the year. THANKS RICK |
[2013-03-27 02:18:42] |
We see what the problem is. Select Chart >> Chart Settings. At the top of the first tab there will be a list box that contains "Historical Chart". You will want to select Historical Chart. This setting only works with holidays on Historical Daily charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-27 05:16:13
[2013-03-27 02:40:27] |
I SEE, IS THERE ANYWAY TO MAKE THE COLUMNS SHOW UP ON INTRADAY CHARTS ? THE INTRADAY I USE IS THE CME.9:05 - 1:00, ? THANKS RICK |
[2013-04-02 03:20:20] |
No.
