Date/Time: Fri, 26 Apr 2024 05:33:01 +0000
My trade position is hidden behind my horizontal lines
View Count: 302
[2023-01-24 23:53:46] |
User409264 - Posts: 12 |
Hi SC Support, Would think this is a common problem with an easy fix; however, cannot locate it and have tried off and on for several days. I have a lot of horizontal lines on my charts and when I enter trades or set pending positions on my charts the trade position line (think that's the right term) on my chart is hidden underneath my lines. I would think by default the trade position would always be on top? Is there a way to set up SC so the trade position will always be on top and not hidden by my lines. Thank you |
[2023-01-25 15:13:23] |
John - SC Support - Posts: 31131 |
The settings that are available for this moves the drawings to the back. Refer to the two settings starting at the following: Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-25 19:14:15] |
User585104 - Posts: 114 |
Just out of interest, I use the cross-hair all the time and this is above my trade positions. Is there a way to modify that too?
[2023-01-25 19:35:28] |
Hi John, Implementated & Success! Thank you |
