Date/Time: Fri, 26 Apr 2024 19:42:02 +0000
Numbers Bars #Trades displaying incorrect info
View Count: 269
[2023-01-23 19:53:37] |
User661335 - Posts: 6 |
Hi When using volume based candles for Binance data there is a display error in Calculated numbers bars vs chart values tool. I found this across the board on different volumes. Chart values tools seems to display the correct #Trades vs numbers bars calculated showing in the billions Include a screenshot of data extracted with differences noted https://www.sierrachart.com/image.php?Image=167450325322.png Thanks |
Attachment Deleted. Binance Data Volume candles.bmp - Attached On 2023-01-23 19:49:33 UTC - Size: 196.72 KB - 80 views |
[2023-01-23 23:28:05] |
John - SC Support - Posts: 31154 |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2023-01-25 19:29:31] |
Done
[2023-01-25 22:19:04] |
The general issue is that the high volumes for the Cryptocurrencies is more than Sierra Chart is setup to handle. Refer to the information at the following link for how to handle this: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
