Date/Time: Thu, 02 May 2024 00:48:43 +0000
Custom Study .dll does not release from Sierra Chart
View Count: 360
[2023-01-23 18:30:42] |
User900285 - Posts: 84 |
The issue is a minor one but thought I would share. I am working with a custom study that uses additional dependencies and I discovered that there may be something stopping this DLL from being released from Sierra Chart. Normally the Release All DLLs command from the UDP interface works. It works when compiling Sierra Chart Studies locally that do not have any additional dependencies. I did also try releasing this DLL using the manual method in the Build Advanced Custom Studies window. With this particular DLL, as soon the custom study is loaded on a chart, any attempt to replace the file does not work, even after attempting to release the DLL. Sierra Chart needs to be fully shut down in order to replace the DLL. This DLL depends on httplib with OpenSSL, urdl, as well as some boost libraries. |
[2023-01-24 03:10:56] |
Sierra_Chart Engineering - Posts: 14173 |
If that is the experience, then that is what is happening but we do not know why or have any control over this. This is controlled by the operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
