Date/Time: Wed, 08 May 2024 01:25:29 +0000
Chart stuck in 1 min tiem frame
View Count: 1071
[2014-06-05 14:02:10] |
toews&kane - Posts: 209 |
Whenever I open a new chart or duplicate an existing chart. I change the chart to a 5 min time frame it tries to load and then quickly reverts to the one minute time frame. How do I fix this?
[2014-06-05 16:45:07] |
Sierra Chart - Max - Posts: 5608 |
Refer to help topic 18 here: http://www.sierrachart.com/index.php?l=doc/helpdetails18.html Sierra Chart Support |
[2014-06-05 16:45:13] |
Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails18.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
