Date/Time: Sat, 27 Apr 2024 03:39:10 +0000
control bar setting
View Count: 304
[2023-01-23 08:21:46] |
colonwing1888 - Posts: 26 |
Hi, How can I adjust the width of each cell in the control bar. For example , how can I wider the cell A ( line ) as attached photo ? Thanks |
image (2).png / V - Attached On 2023-01-23 08:21:31 UTC - Size: 22.42 KB - 69 views |
[2023-01-26 14:36:38] |
Hi, How can I adjust the width of each cell in the control bar. For example , how can I wider the cell A ( line ) as attached photo ? Thanks Please reply |
[2023-01-26 15:19:48] |
58LesPaul - Posts: 429 |
If you increase the font size of each one it will make it wider Control Bar: Control Bar Buttons Size and Text Size Date Time Of Last Edit: 2023-01-26 15:22:23
[2023-02-06 19:29:26] |
Sierra_Chart Engineering - Posts: 14107 |
There are two ways in which a control bar button can become wider. One way is to add additional text to it. You could add spaces to the left and right of "Line". Another method is to change the font size. Refer to the section here for changing control bar button properties which includes the text and also the font size: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
