Date/Time: Sat, 04 May 2024 02:24:48 +0000
[User Discussion] - Custom trailing stop
View Count: 1564
[2014-06-05 12:08:43] |
djcurcio - Posts: 236 |
Does anyone have the code for or would build a custom trailing stop? Initially it would have a preset stop loss from the entry. Then it would monitor the Keltner mid average line. When the price rise above (or below for a short) the Keltner mid line the stop would move up to a preset that would be equal to the entry price plus a user input increment. For example entry plus 2 ticks. Then the stop would trail up and adjust the stop until the stop would be changed to an increment above or below the Keltner mid - for example Kmid - 2 ticks. Thoughts appreciated. |
[2014-06-05 16:28:31] |
namlem - Posts: 94 |
just a thought, probably you can start looking at AutomatedTradeManagementBySubgraph.cpp... you will find it in SierraChart ACS_Source directory. Date Time Of Last Edit: 2014-06-05 16:28:46
[2014-06-05 16:45:30] |
Sawtooth - Posts: 3993 |
You can also use the Trade Management By Study study based on values in a spreadsheet study. http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#StudyControlledTargetsStops |
