Date/Time: Wed, 02 Jul 2025 05:26:45 +0000
price ticks on chart not showing ES properly - Pic attached
View Count: 509
[2023-01-22 15:18:19] |
HeyUgly - Posts: 253 |
hello, some setting is off, I loaded Emini up and something has happened, its not showing proper tick size in this chart what settings should i check to snap it back? Thanks! |
[2023-01-22 18:34:05] |
ondafringe - Posts: 325 |
Double Check "Chart > Chart Settings > Symbol > Tick Size"
[2023-01-23 04:29:54] |
Sierra_Chart Engineering - Posts: 20036 |
Also check this particular Scale Setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
