Date/Time: Thu, 02 May 2024 10:15:41 +0000
Drawing not copying to other charts on same chartbook
View Count: 424
[2023-01-21 22:08:54] |
User994719 - Posts: 21 |
I have followed all instruction's to copy drawings but cant seem to get it to work. I have attached a screenshot of my settings
Screenshot (4).png / V - Attached On 2023-01-21 22:08:07 UTC - Size: 224.02 KB - 85 views |
[2023-01-23 18:10:35] |
John - SC Support - Posts: 31293 |
You have your setup to copy drawings from Chart #2 to Chart #7. Any drawing on Chart #2 should be showing up in Chart #7 unless you specifically set the drawing to not copy. But, keep in mind that if these are different symbols, then you would need to set the option for Show Chart Drawings for Different Symbols to Yes and even then, the prices are often different enough that you may not see the drawing within the view of the destination chart. If you are still having an issue, then we would need to see the two charts side-by-side so we can see the drawing in the one chart and not see the drawing in the other. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
