Date/Time: Sat, 07 Mar 2026 15:03:13 +0000
Show Orders and Positions
View Count: 1808
| [2023-03-08 16:43:30] |
| Technical - Posts: 158 |
Version 2484 - no change. Well, it worked Sunday night, but just once for one trade. Now it is the same situation. Date Time Of Last Edit: 2023-03-08 16:51:18
| [2023-03-09 09:56:42] |
| Sierra_Chart Engineering - Posts: 23171 |
Definitely the problem was resolved. We do not know why you would have a further issue. It would require a re-examination. First thing is to clear the simulated order fills in the main instance for the symbol and simulated trade account: Trade Activity Log: Clearing Trade Activity Data And see if you have a problem after that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-09 09:57:16
| [2023-03-09 14:58:24] |
Perhaps something I need to delete, purge, reset? I exited Sierra 2484, erased all TradeActivityLog*simulated.data files and restarted. No change. |
| [2023-03-09 19:49:53] |
See enclosed.
| [2023-03-11 12:31:15] |
We will have to do a call with you to look at this.
| [2023-03-16 20:04:16] |
I worked on it without success. I erased the configuration and rebuilt from scratch. The problem is solved. Thanks. |
| [2023-03-24 17:42:23] |
To confirm you do not have the problem any longer? We do apologize for the long delay but we have so many other things ahead of this to get to.
| [2023-03-24 18:22:28] |
Yes please close.
