Date/Time: Mon, 20 Jul 2026 01:04:55 +0000
Numbers bars calculated values - view delta as candle sticks in subregion
View Count: 1061
[2023-01-20 03:19:45]
User488241 - Posts: 44
I have a footprint chart with numbers bars calculated values. I wanted to have a subgraph as posted in the picture. I have tried adding study subgraph reference but am only able to produce bars as a display output instead of true candlesticks. Could you please let me know how I could go about replicating the picture?
Thank you!
imagedelta bars.JPG / V - Attached On 2023-01-20 03:15:52 UTC - Size: 53.16 KB - 356 views
[2023-01-20 15:06:36]
John - SC Support - Posts: 47247
If you want to display candlesticks then you would need to have 4 items - an Open, High, Low, and Close. If you know how you want to determine these, then we recommend using the Spreadsheet Formula (Bar) study, which allows you to define all 4 items to create a candlestick bar. Refer to the information for the Spreadsheet Formula here:
Spreadsheet Formula
[2023-01-20 17:14:49]
Just would like to confirm the formula values would be:
open - 0
High - id4.sg4 (+delta sum)
Low - id4.sg5*-1 (-delta sum)
Close - id4.sg1 (delta)
Date Time Of Last Edit: 2023-01-20 17:26:50
[2023-01-20 17:37:32]
If that works for you, then that is fine.
Just one thought - instead of having the Open at 0, you could use the Close of the previous bar. So the Open formula would be ID4.SG1[-1].
