Date/Time: Thu, 11 Jun 2026 20:22:59 +0000
Analysis>Studies>Show Study Description - error
View Count: 1826
| [2014-06-04 23:45:45] |
| User13668 - Posts: 296 |
I get the attached error message when trying to perform the above. I have tried searching the help manual but can find no reference to this function |
| [2014-06-04 23:51:56] |
This means a web browser was not running on your system at the time you clicked the button to show the study description, or the web browser is not registered as the default browser on your system. What web browser are you running?
| [2014-06-04 23:56:08] |
IE 9 and it is running. OS is Windows Vista |
| [2014-06-05 02:07:36] |
We recommend getting off Vista as soon as you can. Here is the relevant documentation to help you make it the default browser: http://windows.microsoft.com/en-US/internet-explorer/make-ie-default-browser#ie=ie-9 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-05 02:08:07
