Date/Time: Sat, 12 Jul 2025 00:50:34 +0000
Volume profile issues
View Count: 411
[2023-01-19 17:00:01] |
coachted - Posts: 436 |
Attached please find a copy of a chartbook containing a 20 day volume profile located all the way to the right of the chart....I do not understand why the 20 Day Volume point of control is 3845 when clearly the highest volume node is 3862.25...can you please advise
Date Time Of Last Edit: 2023-01-19 17:00:42
[2023-01-19 18:20:57] |
John - SC Support - Posts: 40857 |
The following link is an image of what we see. The POC at 3845.0 is definitely correct and the Crosshairs show that it is slightly longer than the bar around 3862.25. https://www.sierrachart.com/image.php?Image=1674152333219.png If your data shows something different then please get us an image. Also, to verify the data, turn on the display of the Volume numbers so you can be sure to compare the actual values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-20 14:53:43] |
Thank you...i will turn on the numbers to clarify going forward...much appreciated
