Date/Time: Sun, 28 Apr 2024 08:37:01 +0000
Tools data values on a Spreadsheet ?
View Count: 1095
[2014-06-04 13:21:56] |
JordiE - Posts: 38 |
Hi Support Team, I hope you're fine.... Could you be so kind to inform if there is any way to get the data results from any tool (e.j. Fibonacci extensions price data values) on a spreadsheet column ? Thanks in advance for your help. With my best regards Jordi |
[2014-06-04 16:53:09] |
No. This is not supported.
[2014-06-04 19:01:07] |
Ok, thanks so much, for your quick reply. Best regards Jordi |
