Date/Time: Tue, 07 May 2024 02:03:29 +0000
estudio trading scalping automatizado
View Count: 256
[2023-01-17 01:09:51] |
luciana - Posts: 24 |
Hola Quisiera probar la version de prueba de : Sistema simple de scalping >> el comercio automático de garrapatas como puedo hacerlo? Gracias |
[2023-01-17 15:26:05] |
John - SC Support - Posts: 31419 |
From Google Translate: Hello
I would like to try the trial version of: Simple scalping system >> automatic tick trading how can I do it? Thanks You would need to ask the creator/seller of that software. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
