Date/Time: Fri, 26 Apr 2024 00:27:47 +0000
HighLow for time period - Going through the weekend
View Count: 361
[2023-01-15 22:10:34] |
User710679 - Posts: 43 |
Hi, i want to highlight the high and low of a specific range every day of the week. In order to do that, i am using the indicator: "High/Low for time period". In this case, i am using start time: 19:30 and end time 20:29:59, and line stop time: 01:59:59. However, when it goes through the weekend, the result is not as expected, because it somehow takes the previous friday and it extends the line through the weekend, even i am selecting "NO" for "Friday evening extends into Sunday". This last feature seems it is not working. Has anyone gone through this issue before? Any idea how to fix it? I am attaching a screenshot and a chartbook. thanks a lot! |
Example Sierra chart.png / V - Attached On 2023-01-15 22:09:11 UTC - Size: 65.99 KB - 69 views Test.Cht - Attached On 2023-01-15 22:10:17 UTC - Size: 4.64 KB - 76 views |
[2023-01-16 16:59:03] |
John - SC Support - Posts: 31131 |
The reason for this is because it is extending the bar until it finds the 1:59:59 stop time. Since there are no trades between Friday after 17:00 in your chart until Sunday evening, the line is extending to that time. A couple of options for ways to deal with this would be to either use the Spreadsheet Study and create an IF statement that checks if it is a Friday and then stops the line at whatever time you would want. Or you can modify the source code and add a special case for Friday evenings. Refer to the following for the Spreadsheet study: Using the Spreadsheet Study And refer to the following regarding modifying studies: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-16 22:02:32] |
Thanks for the response. i am trying to modify the source code, but i gett this error when i remote build it: <html> <head><title>502 Bad Gateway</title></head> <body> <center><h1>502 Bad Gateway</h1></center> <hr><center>nginx/1.23.1</center> </body> </html> Any idea what is happening? THanks |
[2023-01-16 22:39:30] |
I just tried as well and am getting an error (although not the same one you are). So it appears there is something not quite right with the remote build at the moment. We are looking into it.
[2023-01-24 05:50:10] |
User682080 - Posts: 5 |
Just wanted to check in to see if there happen to be any new updates regarding the investigation into this request.
[2023-01-24 15:56:53] |
Sorry, that issue was resolved that evening. You should be able to do a remote build now.
