Date/Time: Sat, 04 May 2024 09:35:18 +0000
DOM, big sizes
View Count: 339
[2023-01-14 16:42:35] |
OriolCasas - Posts: 155 |
Hello, I currently look at order flow with a footprint and a DOM (as you can see on the picture attached) I found out on thiner products like CL or RTY that when there are is a big size on the DOM on a certain tick, all the small sizes around the price that is currently negotiationg are too small too really see the size. Is there anyway I can configure the DOM so when there is big size offered it doesn't look as big and the rest of the size so small? Thank you |
Order flow pic for Sierra support.png / V - Attached On 2023-01-14 16:41:16 UTC - Size: 189.33 KB - 84 views |
[2023-01-16 15:28:22] |
John - SC Support - Posts: 31362 |
We are not really understanding what you are wanting. Can you please point out the issue in the image, or give us some additional information to understand better.
[2023-01-16 15:38:07] |
Here's an attached image of RTY right now. As you can see on the DOM on the picture attaced, there is a huge 214 and 218 lot offered, when there is a big size like that offered the rest of the small 12, 11, 24 lots offered look smaller and similar size or really similar size, which makes it difficult to read the DOM on a fast pace and have a proper read. Is there anyway when there is a +100 lot offered in RTY for example, I could configure something so it doesn't look that big and the rest of the sizes smaller? Thank you |
RTY Footprint.png / V - Attached On 2023-01-16 15:32:51 UTC - Size: 52.97 KB - 81 views |
[2023-01-16 18:29:57] |
We see that you are referring to the length of the bars in the DOM Graph. The only option you have is to increase the length of the bars so you can better differentiate the smaller values when there is a large value. There is no way to filter out, or change how the bar acts. Refer to the following settings for the DOM Graph: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
