Date/Time: Mon, 06 May 2024 11:06:13 +0000
Nit picky question about OHLC bars
View Count: 1956
[2013-05-01 04:55:28] |
pe1111112 - Posts: 35 |
Hi, By default it seems the open and close points are thicker than the bar's width. It appears that the bars are 1 pixel in width but the little parts that stick out to mark the open and close are 3 pixels in thickness. Is there a way to adjust the thickness of the open and close parts so they could be 1 or 2 pixels? This isn't high priority at all, just something I was wondering when I was looking through the settings. Thanks! |
[2013-05-01 09:18:17] |
You can control the width of the Open and Close dashes through Global Settings >> Graphics Settings.
[2013-05-01 14:46:42] |
Cool, thanks. I saw Chart > Graphics Settings but not Global Settings > Graphics Settings.
