Date/Time: Sun, 28 Apr 2024 16:14:54 +0000
Daily average range
View Count: 1279
[2014-06-03 16:47:20] |
Dom7364 - Posts: 257 |
Is there a way to calculate and display the daily average range for a given instument?
[2014-06-03 17:04:16] |
Yes. Open a Historical Daily chart. You could use the Average True Range study. Or you can use the Bar Difference study and then base a Moving Average study on that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-03 21:14:55] |
average true range study displays 0 in the value scale... Can we change this to get actual values which is the whole point?
[2014-06-04 07:34:12] |
Yes. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/helpdetails32.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-04 08:28:52] |
Ok, what I meant was: Is there a way to calculate the yearly average range. So an average of the last 365 days. WHat would be the best way to do that please? Many thanks |
[2014-06-04 08:39:58] |
Set the Length input of the Moving Average or the Average True Range study to the number of trading days in the year and the value of it at the last bar would be the yearly average.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-04 08:40:39
