Date/Time: Wed, 01 May 2024 23:32:57 +0000
Problem with ES chart
View Count: 1082
[2014-06-03 15:57:06] |
User85629 - Posts: 11 |
I have 4 charts set up with CTMO on. 3 of the charts show Orders & Position except the ES chart which shows only orders. Even when I close it and open a new chart it still will not show position????
[2014-06-03 16:16:29] |
You are referring to Trade >> Chart Trade Mode On. Go to the chart that does not show the Position and select Trade >> Attach Trade Window to Chart. Is the Position Average Price you see displayed, within the price range of the chart? Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-03 16:17:09
[2014-06-03 16:35:55] |
It shows: (-4@0.00) I have 4 short but it does not show the avg price like on the other charts. Also the P/L: 0.00P
[2014-06-03 16:40:06] |
This is why you do not see the Trade Position line. The other charts should also show the same Trade Position Average Price unless you are using the order fill calculated position with those: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#OrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-03 17:00:51] |
Thanks, that worked. One other question: what causes the trade position the change back and forth between green and red?
[2014-06-03 17:06:40] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalTradeSettings.html#ChartTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
