Date/Time: Fri, 13 Nov 2026 20:12:01 +0000
Order allocation for 2 different accounts
View Count: 711
| [2023-01-12 16:51:41] |
| User449246 - Posts: 13 |
Can order allocation works for 2 different accounts? if yes how do they work?
| [2023-01-12 17:42:28] |
| John - SC Support - Posts: 48527 |
The Order Allocation to Trade Accounts works with multiple accounts that are accessible through the same login to your trading service. If the accounts are through different trading services, or have separate logins, then this feature does not work in this case. Refer to the information on this at the following link: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
