Date/Time: Fri, 13 Nov 2026 20:12:03 +0000
Custom radio buttons
View Count: 633
[2023-01-12 08:16:56]
AMINE BERRECHACH - Posts: 26
Hi a friend of mine want a button that will change the footprint from delta to volume without having two charts
I was thinking if it is this Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events
Like a button that will change 2setting
Is this exist is sc or not
If it exist can you help me on how to do it
Thanks in advance
[2023-01-12 16:01:01]
You can use Study Collections for this with different Numbers Bars configurations:
Study Collections
And then use Control Bar buttons to change between saved study collections:
Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts
It is also possible to create a custom study that looks for a particular control bar button press and then makes the desired changes. Refer to the following:
Date Time Of Last Edit: 2023-01-12 19:40:51
