Date/Time: Fri, 13 Nov 2026 20:12:06 +0000
graphique
View Count: 656
| [2023-01-11 21:02:05] |
| Utilisateur459167 - Posts: 4 |
bonjour mon graphique est en retard de 15mn sur l'heure exact j'ai le package 11 merci pour votre reponse
| [2023-01-11 22:37:36] |
| John - SC Support - Posts: 48527 |
From Google Translate: hello my graph is 15 minutes late on the exact time I have package 11 thank you for your answer
you are not setup to get any real-time data from us, and you are not connected to any trading service for which you could be getting the data from. What are the exchanges for which you want real-time data? With regards to CME Group data, be sure you are aware of the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
