Date/Time: Fri, 13 Nov 2026 20:12:08 +0000
Depth of Market
View Count: 768
[2023-01-11 20:17:01]
dixon - Posts: 5
Hello, I dont know why the depth of market is not showing any other resting orders besides where price is trading at.
imageScreenshot 2023-01-11 150602.png / V - Attached On 2023-01-11 20:16:42 UTC - Size: 12.1 KB - 195 views
[2023-01-11 22:17:05]
We do not have enough information from the image, but the most likely thing is that you are not displaying the correct columns. Make sure you are displaying the Bid and Ask or the Buy/Bid Sell/Ask columns. Refer to the information here:
Global Trade Settings Windows: Sell Order Column - Left/Center/Right Aligned
[2023-01-11 23:41:41]
dixon - Posts: 5
It seems like whenever I turn on **use as trade only symbol** my depth of market only shows the top of book.
I trade Micro ES and data from ES.
[2023-01-11 23:54:25]
dixon - Posts: 5
when i have both symbol and trade and current quote symbol set to ES. It is fine but once I change my (use as trade only symbol) to Micro ES, the dom is empty, no order displays
[2023-01-12 15:12:47]
The Market Depth information that is displayed will be for the symbol set in Trade and Current Quote Symbol unless you also have the option for Use as Trade Only Symbol set to Yes.
But, there is no reason why you should not be getting the Market Depth data for the MES, as you are setup to get real-time data including Market Depth data for the CME exchange, on which both the ES and MES are traded.
Please open a new chart for the MES and ensure you have the DOM displayed (either Chart Trade Mode On, or the Market Data Columns). If you are not seeing the full market depth for that symbol then go through the information at the following link and see if you find the issue:
File Menu: Not Receiving the Full Number of Market Depth Levels
