Date/Time: Sat, 17 Oct 2026 13:05:51 +0000
Applying a Study Collection to a Chart
View Count: 1616
[2023-01-11 11:00:28]
User513390 - Posts: 49
Dear Support,
I did
Select the name you saved it as from the list on the Analysis menu. This menu is on the Sierra Chart main window.
The attached file is saved to the Sierra Chart Data Files Folder.
But nothing happens when i apply it as can be seen in Print Screen
Would you please help me,
Rodney
imageCapture d’écran (3).png / V - Attached On 2023-01-11 10:57:53 UTC - Size: 303.5 KB - 345 views
attachmentFoot Print IMBALANCES1.StdyCollct - Attached On 2023-01-11 10:58:14 UTC - Size: 93.23 KB - 329 views
[2023-01-11 16:31:05]
John - SC Support - Posts: 48239
The image you provided is how you save a Study Collection, but it is not how you apply a Study Collection to a chart. To apply a Study Collection to a chart select the Analysis menu and you will see the Study Collection name in that menu towards the bottom. Select the name of the Study Collection you want to apply and it will then be applied.
Refer to the information here:
Study Collections: Applying a Study Collection to a Chart
[2023-01-12 13:23:40]
Thank you for your help.
But unfortunaltey when i apply a Study Collection to a chart and by selecting the Analysis.
It does not load the Study Collection.
Can you help,
Rodney
[2023-01-12 16:21:52]
We just tried the Study Collection that you had attached to this thread in the beginning. There are no studies contained within that file, therefore there is nothing that is added to the chart. You would need to see if you can get another copy of that file from wherever you got it.
[2023-01-13 09:07:36]
I thank you very much,
Would you mind checking the below files to see if they are emply.
Thank you very much for your support.
Best regards
Rodney
attachmentFootprint Bid x Ask (Ø Diag).StdyCollct - Attached On 2023-01-13 09:07:06 UTC - Size: 271.77 KB - 464 views
attachmentFoot Print IMBALANCES BUND.StdyCollct - Attached On 2023-01-13 09:07:20 UTC - Size: 93.23 KB - 483 views
[2023-01-13 17:29:25]
The file "Footprint Bid x Ask ( Diag).StdyCollct" has studies within it. The other one either does not, or is too old to be used.
