Date/Time: Mon, 29 Apr 2024 08:30:24 +0000
Cumulative Delta Bars Volume
View Count: 1122
[2014-06-03 12:56:38] |
gmorgan111 - Posts: 121 |
For the second day in a row when I turned on my computer and Sierra Charts and loaded my chartbooks my cumulative delta bars volume and ticks are not showing the data from when the time I turned off my computer until this morning when I turned it on. The bars start plotting when I load the charts. I have the setting right to not reset each day. Can you please help Thanks |
[2014-06-03 16:01:35] |
The problem is you do not have the CME exchange activated. It needs to be enabled here: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges Restart Sierra Chart after activating the exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
