Date/Time: Fri, 13 Nov 2026 20:13:57 +0000
Ask_Bid_Volume_Difference_Bars remove zeros
View Count: 655
| [2023-01-10 23:27:15] |
| User993440 - Posts: 26 |
Hi, I'm using the Ask_Bid_Volume_Difference_Bars study with the symbol F.US.EPH23. The bid/ask difference includes .00 after the main positive or negative number (see attached screenshot). for instance 1048.00 or -234.00 Is it possible to remove the '.oo'? Thanks Date Time Of Last Edit: 2023-01-10 23:27:56
| [2023-01-11 15:18:50] |
| John - SC Support - Posts: 48527 |
Whatever study you are using to display those values - set the Value Format to 1. Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
