Date/Time: Sat, 17 Oct 2026 13:05:05 +0000
Symbol missing in Symbol Settings
View Count: 970
[2023-01-09 12:56:41]
like2trade - Posts: 119
The symbol information for 6ZH23-CME is missing for translation to Interactive Brokers symbol equivalent.
[2023-01-10 05:27:33]
Sierra_Chart Engineering - Posts: 25199
This should now be resolved.
[2023-01-10 05:43:08]
I tried it and it is still not working.
[2023-01-10 14:18:57]
Therefore, manually translate the symbol. As we pay more close attention to the symbol you mentioned there may not be a translation pattern set up. Just do the translation manually by changing the symbol in Chart >> Chart Settings >> Symbol >> Symbol.
The Translate Symbols to Current Service feature is there for convenience. It is not there to work under all circumstances. You should not be switching services frequently in Sierra Chart. However, instead install multiple installations of Sierra Chart, one for each service you want to use:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2023-01-10 14:19:43
[2023-01-10 14:32:09]
This symbol is for South African Rand CME futures. When connected to Interactive Brokers and searching through File/Find Symbol, there is no listing for this under Futures - CME.
[2023-01-10 17:01:35]
What is the symbol that Interactive Brokers uses for South African Rand CME?
[2023-01-10 17:22:26]
I believe it should be ZAR-202303-CME.
Thank you.
[2023-01-10 23:10:55]
This has now been added.
However, there are no translation patterns set up for it.
[2023-01-11 05:58:01]
I see it now under File/Find Symbol and am able to open a Historical Chart for the symbol ZAR-202303-CME. Thank you.
FYI, the translation is still not taking place when switching between SC Data - All Services and Interactive Brokers.
The Continuous Futures Contract feature under Chart Settings/Symbol is not working for this symbol when the Data/Trade Service Setting is Interactive Brokers.
Thank you.
[2023-01-11 15:17:34]
There should not be a problem with this:
And perform the data download again:
[2023-01-12 02:03:18]
I followed your directions but I am still having a problem with:
I do not have this problem when the Data/Trade Service Setting is SC Data - All Services
I have attached a screenshot of the chart with symbol 6ZH23-CME for Data/Trade Service Setting is SC Data - All Services.
I have attached a screenshot of the chart with symbol ZAR-202303-CME for Data/Trade Service Setting is Interactive Brokers.
It is exactly the same chart and I only changed the symbol and then the Data/Trade Service Setting.
image6ZH23-CME [C][M] Daily #45 2023-01-11 17_56_59.585.png / V - Attached On 2023-01-12 01:58:29 UTC - Size: 26.77 KB - 288 views
imageZAR-202303-CME [C][M] Daily #45 2023-01-11 17_52_11.048.png / V - Attached On 2023-01-12 01:58:36 UTC - Size: 18.31 KB - 254 views
[2023-01-13 15:33:09]
This is now resolved.
And reload the chart with Chart >> Reload and Recalculate.
[2023-01-13 17:31:16]
The Continuous Futures Contract feature is working great. Thank you very much.
The only thing still not working is:
The symbol information for 6ZH23-CME is missing for translation to Interactive Brokers symbol equivalent ZAR-202303-CME.
The translation is still not taking place when switching between SC Data - All Services and Interactive Brokers.
Thank you.
[2023-01-13 18:08:24]
There is no symbol translation. We will not be setting that up for this.
Date Time Of Last Edit: 2023-01-13 18:08:34
