Date/Time: Sun, 28 Apr 2024 07:45:18 +0000
Sizing seems off on new PC
View Count: 356
[2023-01-09 09:26:25] |
User154791 - Posts: 14 |
Hi after getting a new PC and using my chartbooks I have had some issues. As you can see on my laptop (a very small screen) it allows far more TPO profiles on the screen than my PC which is uisng much bigger monitors. I am not sure why I am having this problem as I didn't on my old PC. When I try to resize it at the bottom it seems to be at its max. Any help would be great, look forward to hearing from you! |
photo_2023-01-09_09-25-01.jpg / V - Attached On 2023-01-09 09:25:59 UTC - Size: 80.16 KB - 62 views photo_2023-01-09_09-25-28.jpg / V - Attached On 2023-01-09 09:26:06 UTC - Size: 108.53 KB - 61 views photo_2023-01-09_09-25-30.jpg / V - Attached On 2023-01-09 09:26:12 UTC - Size: 107.02 KB - 58 views |
[2023-01-09 17:14:57] |
We see that on your old PC you were looking at daily TPOs, but on the new one they are Monthly. Offhand, the difference would most likely be due to the amount of data available, such that you do not need more TPO Profiles than what is displayed in the Monthly one.
[2023-01-10 09:15:27] |
Hi, I attached a screenshot of my new PC (dual monitor) TPO's. You can see the daily on the left, and the monthly on the right. I then attached 2 screenshots from my laptop, one of the daily TPO and the other of the monthly. As you can see both of the TPO charts on my laptop fit in way more profile, despite having a smaller screen. (my pc and laptop both have the same amount of data/days to load). I can tell the sizing on my new PC is off, the profiles are too stretched. Thanks |
[2023-01-10 16:09:50] |
No image attached to the last post.
