Date/Time: Mon, 06 May 2024 13:25:35 +0000
Numbers Bars Calculated Values not showing Unicode/Delta symbol on label
View Count: 390
[2023-01-09 06:37:23] |
User719512 - Posts: 227 |
Hello, Trying to get the labels on Numbers Bars Calculated Values to show a delta, Δ, character. Appears to work in settings dialog, just not on the Grid in region 2. Please see attached image for what I am seeing. Have tried switching fonts, currently using Sequoe UI everywhere, did not make a difference. Using v2462. Thank you. |
NBCV-unicode-delta.png / V - Attached On 2023-01-09 06:34:43 UTC - Size: 149.75 KB - 71 views |
[2023-01-09 23:16:46] |
Jeffrey - Posts: 2098 |
Unicode characters are not supported when using OpenGL for chart graphics. This setting is located at: Global Settings >> Graphics Settings - Global >> Other >> Use OpenGL for Chart Graphics |
[2023-01-10 04:11:08] |
Wow. Thank you for that info Jeffrey. For perf reasons, I will run with OpenGL turned on and sacrifice the unicode characters. Yes, turning off OpenGL did work to show that delta unicode character.
