Date/Time: Sat, 04 May 2024 02:59:11 +0000
S&P quit charting
View Count: 1012
[2014-06-02 19:19:40] |
sierra - Posts: 22 |
S&P quit charting at 15:14. Please let me know if this is you or Transact? |
[2014-06-02 19:22:34] |
Sorry I forgot to mention the Dow hasn't worked for over a month and I would like to know if others are having this problem as well.
[2014-06-02 20:18:37] |
Infinite - Posts: 134 |
I had NQ and Ym show hardly any activity today...with the correct contract month showing. I use TT/net....only traded ES and RT today fortunately. Actually closed out charts 3 times today with no success!!! Date Time Of Last Edit: 2014-06-02 20:19:54
[2014-06-02 21:05:49] |
Refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html If help topic 3.4 indicates you are not receiving the real-time data, and no other section on that page is helpful, then contact your trading service about the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 21:37:29] |
User13668 - Posts: 291 |
@Infinite: If you are using TTNet/AMP then your issue sounds like the one I had twice today - see this thread: TT/AMP intraday historical data - problem?? |
