Date/Time: Tue, 30 Apr 2024 07:42:19 +0000
Historical Intraday data not downloading
View Count: 1778
[2013-05-01 02:36:52] |
Miracle 007 - Posts: 17 |
I have iQFeed as my data on one instance of SC and IB trading on another. I have the data setting to download tick data for the last 30 days but its only showing the last 5 days on the intraday chart. In chart settings it shows date range in file 4-25 to 4-30. I have it set to download 30 days worth however. How to I force it to download the data? And in what instance do I need to make the changes? |
[2013-05-01 03:31:21] |
You need to make this change within the copy connected to the iQFeed. Follow through the instructions in help topic 42.1 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html#h42.1 Although, when it comes to modifying the Chart >> Chart Settings, you need to do this in the copy connected to Interactive Brokers. Also be aware of the information in this section: http://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html#TickLimitMarketHours Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-01 19:37:39
[2013-05-01 19:34:31] |
How do I get the current days daily to update on my trading instance. The current day on the daily shows up on the source instance, but not on my trading instance. I think the daily is pulling from the historical data? The intraday instructions worked perfectly, btw.
[2013-05-02 01:09:56] |
You need to set the Alternate Real-time Update Symbol as explained in step 9 here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-02 01:10:38
