Date/Time: Tue, 07 May 2024 16:39:59 +0000
Multiple entries not working.
View Count: 405
[2023-01-05 18:57:04] |
User538264 - Posts: 16 |
Hi, I have set the "Allow Multiple Entries in Same Direction" as 'Yes' but multiple entries are not being taken. I can see the buy entry signal on chart as well as on spreadsheet but it is getting ignored. I checked the trade activity log but could not find a solution. Help me please. Thank you. |
[2023-01-05 23:14:52] |
John - SC Support - Posts: 31433 |
Check the Maximum Position Allowed on the Inputs for the study you are using (if it has this option) and make sure it is greater than the total quantity that you are trying to create. Also check the Global Settings >> Symbol Settings and see if the Use Global Trade Position Limit is enabled and what value is set in it, if this is perhaps blocking your additional orders. If not the above, then check the Trade >> Trade Service Log after you try to place an additional trade and see what it states for why it is not placing the order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
