Date/Time: Sun, 05 May 2024 18:39:01 +0000
ICEEU data missing
View Count: 261
[2023-01-04 07:06:25] |
User197029 - Posts: 45 |
The historical data for Friday, 30th December 2022 is missing for ICEEU symbols. This was not a holiday. Example: CH23-ICEEU or RCH23-ICEEU Can you check please. Thank you |
[2023-01-04 18:54:42] |
Sierra_Chart Engineering - Posts: 14234 |
It may have been a holiday for ICE. First check with the ICE on this. If the data is not there, then most likely it is because the exchange did not provide data for that day. It would make sense. It is a holiday weekend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 18:55:48
[2023-01-05 06:29:34] |
No, it was not a holiday for ICE (see attached). The intraday data exists since the intraday charts are loading correctly, only the historical data is missing.
RC_2022_12_30.pdf - Attached On 2023-01-05 06:28:26 UTC - Size: 66.06 KB - 99 views |
[2023-01-05 18:32:51] |
We have asked our data provider about this. We will see what they say.
