Date/Time: Sun, 19 May 2024 02:02:25 +0000
[User Discussion] - Study for 'Time' that High or Low was made
View Count: 992
[2014-05-31 00:29:38] |
User24187 - Posts: 54 |
For a given session, is there a study that can determine the Time at which High and Low was made?
[2014-05-31 00:55:24] |
The closest there is, is the Daily OHLC - Single Point study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-31 00:55:43
[2014-05-31 15:53:35] |
vegasfoster - Posts: 444 |
How are you going to use it?
[2014-05-31 16:01:19] |
By dividing Daily Range with Time difference between High/Low, I wanted to gather historical data on the speed of price movement. Needed for spreadsheet.
[2014-06-09 23:28:18] |
Sorry, missed this, do you still need help with this?
