Date/Time: Tue, 07 May 2024 10:26:45 +0000
Coloring Method (seperate bid/ask volume coloring)
View Count: 1079
[2014-05-30 15:20:41] |
User78745 - Posts: 38 |
Dear all, I was wondering if it's possible to have the volume profile one a bar with a seperate bid/ask volume coloring. Please find a picture attached. I need same as VbyP (seperate bid/ask volume coloring) but on the numbers bar study. Thank to all |
Private File Attachment Deleted. Attachment Deleted. |
[2014-06-01 12:13:19] |
Dear all, anyone knows how to set up ? |
[2014-06-07 03:32:15] |
The documentation here explains how to set up a Volume by Price study that displays a Volume Profile for each bar: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#SingleBarVolumeProfiles You can then set the coloring of the volume bars to show the bid volume and the ask volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
