Date/Time: Sat, 04 May 2024 15:03:54 +0000
Mes données sont en retard
View Count: 297
[2022-12-20 15:56:13] |
User745337 - Posts: 1 |
Bonjour, je n'arrive pas a me connecter à mes données en temps réel |
[2022-12-20 17:59:34] |
John - SC Support - Posts: 31362 |
Our servers are showing that you are connecting to Rithmic. In order to connect to an external service or get real-time data, you need to be on one of the Integrated Packages. We have given you an evaluation of Package 12 for the next 30 days, which will allow you to connect to your Rithmic account during that time. Just be sure to change your package to Package 11 before the end of these 30 days in order to be able to continue to connect to your Rithmic account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
