Date/Time: Sun, 28 Apr 2024 11:54:24 +0000
renco chts for YMM4
View Count: 1398
[2014-05-29 00:33:15] |
User92798 - Posts: 8 |
when I try to switch a cht to renco on the YMM4 I get a code that says ; encountered an out of memory condition when loading cht data, or same "when calling a study function" ; how can I get a YMM4 cht on renco bars?.. thanks Milton.
[2014-05-29 00:43:09] |
Did you select the Bar Period Type >> Renko Bars setting within Chart >> Chart Settings or use one of the Renko studies? Do not use the Renko studies. They are only for back compatibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-29 14:33:33] |
I get a " out of memory condition when loading " when I try to set up a renco on YMM4, have you tried this ?thanks .
[2014-05-29 16:24:42] |
We need to understand how you are setting up the Renko bars. Did you select the Bar Period Type >> Renko Bars setting within Chart >> Chart Settings? Here are the instructions for that: http://www.sierrachart.com/index.php?l=doc/doc_RenkoCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-29 17:54:50] |
I go to C S, then bar period, and select renco bar in ticks. over in the 'graph draw type' comes up automaticly with 'renco brick with wicks.' and I get out of memory code.
[2014-05-29 18:00:39] |
What is the symbol of the chart? And what is the Tick Size set to in Chart >> Chart Settings? Set the Days to Load setting in Chart >> Chart Settings to 5 or less. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-29 18:01:19
[2014-06-02 16:54:55] |
for the YMM4 cht. what should the; 'price display format ' value be? also what should the 'tick size ' be? and the volume at price multiplier? value?
[2014-06-02 16:58:51] |
what should the multiplier for ZSN4 ? and tick size be? and price display format? value.
[2014-06-02 17:30:02] |
The settings for these symbols are already preset. To make sure you have the correct settings, follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Be sure to apply them to the chart to make sure they are correct. The Volume at Price Multiplier should be 1 for Intraday charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 17:45:51] |
My last two posts were for RENCO chts YM and ZS. thanks
[2014-06-02 17:54:43] |
Yes we know.
