Date/Time: Fri, 13 Nov 2026 21:11:09 +0000
VWAP study beyond the yearly
View Count: 955
[2022-12-05 00:07:57]
yqz - Posts: 21
I currently have the VWAP study for the daily, weekly, monthly, quarterly, and annual levels. Is it possible to go broader? Like biannual, 5-year, 10-year VWAP, etc.? Thank you for your time.
[2022-12-05 00:23:39]
Yes because you can specify a number of years through the Time Period Length input.
[2022-12-05 01:42:09]
yqz - Posts: 21
Thanks for the quick reply, I found the study under Analysis > Studies > Settings for VWAP. Here I see Vwap period type for bar, daily, ..., yearly. There doesn't seem to be an option to set the number of years. I found another link here [Volume Weighted Average Price (VWAP) with Standard Deviation Lines] which explains that I can go to Chart > Chart Settings > and look for Time Period Length and Time Period Type. I can't seem to find these options however. Furthermore, I'm currently using a historical chart, so the session times is grayed out. If you could help explain what to do, I would greatly appreciate it. Thank you again for your assistance thus far.
[2022-12-05 14:10:03]
The number of Years is set with the Time Period Length Input with the study.
Instructions to access Input settings:
Chart Studies: Adding/Modifying Chart Studies
