Date/Time: Fri, 13 Nov 2026 21:11:12 +0000
Data Not working well
View Count: 679
[2022-12-02 23:37:16]
User989530 - Posts: 34
Hello support,
On NQZ22-CME flex renko is not working well, im using the second bar mode(they are 12). There are gaps everywhere all the time.
Date Time Of Last Edit: 2022-12-02 23:42:42
imagey.png / V - Attached On 2022-12-02 23:42:29 UTC - Size: 74.37 KB - 184 views
imagez.png / V - Attached On 2022-12-02 23:42:34 UTC - Size: 43.34 KB - 250 views
[2022-12-03 15:23:29]
This could be normal and unavoidable based on the settings you are using. However, set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
