Date/Time: Fri, 13 Nov 2026 21:11:13 +0000
trade issues
View Count: 622
| [2022-12-02 20:00:31] |
| User417569 - Posts: 3 |
i can't change to simulation mode, "trade simulation mode" i click but nothing appens..
| [2022-12-02 22:59:51] |
| John - SC Support - Posts: 48527 |
That is because you are connected to the Trading Evaluator, for which there is not a Simulation Mode available since this is a Trade Simulation itself. You would need to change your Current Selected Service to SC Data - All Services in order to be able to enable "Trade Simulation Mode".
| [2022-12-04 19:52:50] |
| Sierra_Chart Engineering - Posts: 25422 |
Refer to: Simulated Futures Trading Service: Using Internal Sierra Chart Trade Simulation Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
