Date/Time: Fri, 13 Nov 2026 21:24:45 +0000
[Programming Help] - How to create Market Statistics
View Count: 688
[2022-12-02 11:13:05]
User222326 - Posts: 3
Hello Support
I use market profile and I would like to check probabilities for each setup I have on intraday session using Sierra and Denali.
for example, Break of Initial balance, opening range, Gap filling, return to prior range. Percentage opening Higher, inside or lower.
I already checked Sierra Chart Market Statistics but didn't help much.
If there is something there with more detail
Best regards,
Daniel
[2022-12-02 17:35:57]
You would have to create your own program to do everything you are wanting. Refer to the information for our Advanced Custom Study Interface Language (ACSIL) starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
