Date/Time: Fri, 13 Nov 2026 21:24:49 +0000
trading locked
View Count: 712
| [2022-12-02 09:23:14] |
| User712123 - Posts: 2 |
Hi, I can't see any movments on my charts. The market is totally stuck at certain levels and it doesn't move. EUR/USD is stuck at 1.05341 and GBP/USD at 1.22780. What I have to do? |
| [2022-12-02 15:15:48] |
| Sierra_Chart Engineering - Posts: 25422 |
If you still have a problem provide us the following information: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. We just need to know about one symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
