Date/Time: Fri, 13 Nov 2026 21:24:53 +0000
Packages and data what to get?
View Count: 1661
| [2022-12-02 04:47:47] |
| User513352 - Posts: 5 |
Testing out the platform and about to pull the trigger. I am trading ES on a 2000 tick chart exclusively . Will be using AMP FUTURES as broker . I'm assuming im needing to get package 10 or 11? For data is denali included in the package or there are other fees? And is denali better then CQG for tick data. Thanks you very much . |
| [2022-12-02 17:01:39] |
| John - SC Support - Posts: 48527 |
You need to be on one of the Integrated packages in order to be able to connect to an external trading service and get real-time data. As to the particular package, it depends on what you need for your trading. Refer to the following for the differences in the packages: Description of Service Packages and Pricing: Integrated Packages To get the real-time data for the Denali Exchange Data Feed, you need to fill out the Exchange Agreements and activate the exchange(s) you want. There are separate fees for the exchanges. You will find the Setup Instructions for the CME Group data at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* In terms of data quality, the main difference is the historical data. We have 1 tick data going back many years (the amount of data available depends on the symbol, so there is some variance). CQG data is only the current front contract - you can not get any data prior to this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-02 18:58:38] |
So if i get it right , i need Package 10 or 11, and use denali Echange but use cqg for order routing to amp only . I also need to pay for the CME group fees? I only trade E-MINI SP500 on a 2000 tick charts. Thanks you |
| [2022-12-02 22:45:10] |
Yes, you are correct. Also an update to what we wrote above - we were not thinking straight apparently - we do not have support for the CQG data for the CME Group, so you have to use our Denali data feed to get that data. In order to connect to CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-02 23:13:29] |
Thank you very much for the quick answers . Have a great weenk-end
