Date/Time: Thu, 02 May 2024 05:28:31 +0000
"Set X and Y Constant Relationships" Greyed out
View Count: 2364
[2013-04-30 19:02:34] |
emjay2d - Posts: 5 |
Simply put, I want to use "Set X and Y Constant Relationships" but it is greyed out and wont allow me to select that option. http://i42.tinypic.com/5capnn.jpg I found a similar question through search, but the answer given didnt make any sense to me: Scale X & Y Contant Relationship greyed out |
[2013-04-30 19:16:08] |
Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ConstantRelationship We realize the problem is that on your package, this feature is not supported. You will need to be on package 3 or 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-30 19:16:39
