Date/Time: Fri, 13 Nov 2026 21:24:45 +0000
Depth of market on the DOM
View Count: 727
| [2022-12-01 14:51:48] |
| User215984 - Posts: 24 |
Hi, I just switched to 12 - Integrated Advanced MBO package and only receiving a depth of market of 2. I did go though all the docs to change the settings. I must have missed something.
| [2022-12-01 17:56:07] |
| John - SC Support - Posts: 48527 |
You do not have any exchanges active that include the Market Depth data. You can activate the exchange(s) you need at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Also be sure to go through the Setup Instructions for the MBO data here: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
