Date/Time: Fri, 13 Nov 2026 21:24:55 +0000
Multiple Brokerage Accounts
View Count: 701
| [2022-12-01 13:45:14] |
| JGI - Posts: 13 |
Hi, Is it possible to us the "Order Allocation" feature to trade two accounts at the same time. For example, if my sister has an account at AMP, which is where I have my account, can I trade both hers and mine at the same time? Thanks! |
| [2022-12-01 17:21:22] |
| John - SC Support - Posts: 48527 |
Since these are separate accounts, it can not be done. The Order Allocation to Trade Accounts only works with accounts that are all accessible through the same login to the broker. Refer to the following: Order Allocation to Trade Accounts: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
