Date/Time: Fri, 13 Nov 2026 21:24:54 +0000
help
View Count: 813
| [2022-12-01 12:10:05] |
| User193294 - Posts: 3 |
Good morning a need help regarding: out of order timestamps detected. charts tool drawinsgs and some chart studies may not funcion properly; the grafics stopped on the date 01/12/2022 11:26 |
Private File |
| [2022-12-01 12:21:49] |
| Sierra_Chart Engineering - Posts: 25422 |
Refer to: Out of Order Timestamps Detected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 13:15:06] |
I followed the steps and I don't approve
| [2022-12-01 13:36:16] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 14:25:41] |
Software version: 2434 64-bit | 2022-12-01 14:25:00.903 Primary Thread ID: 7960 | 2022-12-01 14:25:00.903 Usage end date: 2022-12-25 | 2022-12-01 14:25:00.903 Enabled for: Advanced Features 2. | 2022-12-01 14:25:00.903 Enabled for: Sierra Chart Historical Data Service. | 2022-12-01 14:25:00.903 Enabled for: Delayed Denali Exchange Data Feed. | 2022-12-01 14:25:00.903 Enabled for exchange2: fairx_exchange.data | 2022-12-01 14:25:00.903 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-12-01 14:25:00.903 Current selected Data/Trading service: SC Data - All Services | 2022-12-01 14:25:00.903 Custom symbol settings values: enabled | 2022-12-01 14:25:00.903 Chart Update Interval: 500 | 2022-12-01 14:25:00.903 Intraday Data Storage Time Unit: 0 | 2022-12-01 14:25:00.903 Time Zone: +00:00:00 (UTC+00) | 2022-12-01 14:25:00.903 2022-12-01 14:25:00 Local computer time in UTC | 2022-12-01 14:25:00.903 2022-12-01 14:25:00 Local computer time in SC Time Zone | 2022-12-01 14:25:00.903 2022-12-01 12:51:58 Server time in UTC | 2022-12-01 14:25:00.903 Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-12-01 14:25:00.903 Program path: C:\SierraChart\ | 2022-12-01 14:25:00.903 Data Files path: C:\SierraChart\Data\ | 2022-12-01 14:25:00.903 OS Version Number: 10.0 | 2022-12-01 14:25:00.903 Locale Setting: C | 2022-12-01 14:25:00.903 DLLs: UserContributedStudies_64.dll | 2022-12-01 14:25:00.903 Allowed protected custom studies: | 2022-12-01 14:25:00.903 Crash reporter started: true | 2022-12-01 14:25:00.903 Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. | 2022-12-01 14:25:09.082 Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. | 2022-12-01 14:25:09.082 Triggering next historical data download in queue. | 2022-12-01 14:25:09.082 Reloading all charts with filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:09.082 HD Request # 46 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data | 2022-12-01 14:25:09.082 HD Request # 46 | Download start date-time: 2022-12-01 00:25:37.000000. File last date-time: 2022-12-01 00:25:37.000000 | 2022-12-01 14:25:09.083 HD Request # 46 | Using server: ds4.sierracharts.com port 10149 | 2022-12-01 14:25:09.083 Socket (4) | Creating socket. | 2022-12-01 14:25:09.083 Socket (4) | New receive buffer size: 5242880 | 2022-12-01 14:25:09.083 Socket (4) | Connecting to IP: 142.215.18.105. | 2022-12-01 14:25:09.083 BTCUSDT_PERP_BINANCE[M] #37 | Reloading chart. | 2022-12-01 14:25:09.135 BTCUSDT_PERP_BINANCE[M] #37 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-12-01 14:25:09.196 BTCUSDT_PERP_BINANCE[M] 1 Min #18 | Reloading chart. | 2022-12-01 14:25:09.266 BTCUSDT_PERP_BINANCE[M] 1 Min #19 | Reloading chart. | 2022-12-01 14:25:09.329 HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-12-01 14:25:09.417 HD Request # 46 | Sending historical data logon request message. | 2022-12-01 14:25:09.417 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | Reloading chart. | 2022-12-01 14:25:09.488 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2022-12-01 14:25:09.488 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2022-12-01 14:25:09.488 BTCUSDT_PERP_BINANCE[M] #3 | Reloading chart. | 2022-12-01 14:25:09.499 BTCUSDT_PERP_BINANCE[M] Renko 5t #4 | Reloading chart. | 2022-12-01 14:25:09.529 BTCUSDT_PERP_BINANCE[M] 1 Min #18 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:09.770 BTCUSDT_PERP_BINANCE[M] 1 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:09.832 HD Request # 46 | Requesting Intraday data. Start date-time: 2022-12-01 00:25:37. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE | 2022-12-01 14:25:10.103 HD Request # 46 | Decompressing data. | 2022-12-01 14:25:10.263 BTCUSDT_PERP_BINANCE[M] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:10.501 BTCUSDT_PERP_BINANCE[M] Renko 5t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-12-01 14:25:10.737 HD Request # 46 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2022-11-30 20:22:20.000000 | 2022-12-01 14:25:10.948 Socket (4) | CloseSocket call. | 2022-12-01 14:25:10.950 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-12-01 14:25:10.950 Historical data download thread signaled to stop. | 2022-12-01 14:25:10.950 HD Request # 46 | Received 3591 Intraday data records from 2022-11-30 20:22:20.000000 to 2022-11-30 21:22:20.000000 (60.0 minutes) and wrote 0 records for BTCUSDT_PERP_BINANCE | 2022-12-01 14:25:10.950 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2022-12-01 00:25:37.000000 | 2022-12-01 14:25:10.950 HD Request # 46 | Completion time: 1s. | 2022-12-01 14:25:10.950 HD Request # 46 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 47 | 2022-12-01 14:25:10.950 Removing historical data download ID 47. | 2022-12-01 14:25:10.950 Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE | 2022-12-01 14:25:10.950 Intraday chart data file opened for BTCUSDT_PERP_BINANCE | 2022-12-01 14:25:10.950 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-12-01 14:25:10.950 Triggering next historical data download in queue. | 2022-12-01 14:25:10.950 No download requests in the queue to start downloads for. | 2022-12-01 14:25:10.950 Socket (4) | Socket gracefully closed by remote side. | 2022-12-01 14:25:11.111 Socket (4) | Closed. | 2022-12-01 14:25:11.111 Reloading all charts with filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:17.977 BTCUSDT_PERP_BINANCE[M] #37 | Reloading chart. | 2022-12-01 14:25:17.978 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | Reloading chart. | 2022-12-01 14:25:17.989 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2022-12-01 14:25:17.989 BTCUSDT_PERP_BINANCE [CBV-D][M] 5 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2022-12-01 14:25:17.989 BTCUSDT_PERP_BINANCE[M] #3 | Reloading chart. | 2022-12-01 14:25:18.019 BTCUSDT_PERP_BINANCE[M] Renko 5t #4 | Reloading chart. | 2022-12-01 14:25:18.041 BTCUSDT_PERP_BINANCE[M] #37 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-12-01 14:25:18.068 BTCUSDT_PERP_BINANCE[M] 1 Min #18 | Reloading chart. | 2022-12-01 14:25:18.296 BTCUSDT_PERP_BINANCE[M] 1 Min #19 | Reloading chart. | 2022-12-01 14:25:18.351 BTCUSDT_PERP_BINANCE[M] 1 Min #18 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:18.790 BTCUSDT_PERP_BINANCE[M] 1 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:18.900 BTCUSDT_PERP_BINANCE[M] #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-11-04 01:12:00. Next Bar Date Time: 2022-11-04 00:52:00. Filename: BTCUSDT_PERP_BINANCE.scid | 2022-12-01 14:25:19.044 BTCUSDT_PERP_BINANCE[M] Renko 5t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-12-01 14:25:19.146 |
| [2022-12-01 14:37:49] |
You are referring to Binance data. Yes there can be out of order timestamps with Binance. We cannot help with that.
