Date/Time: Fri, 13 Nov 2026 21:24:46 +0000
Binance is not giving any data
View Count: 856
| [2022-12-01 01:39:40] |
| User599524 - Posts: 1 |
Hi I am not reiciving any data from binance. I have this message what I should do?
| [2022-12-01 02:46:44] |
| Sierra_Chart Engineering - Posts: 25422 |
This is an issue with Binance. Hopefully it will come back soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 04:25:23] |
| Amelyn - Posts: 46 |
Same, no data the entire day. Any word?
| [2022-12-01 08:36:29] |
| pearlus - Posts: 3 |
Why does this Binance issue not affect your competitors? 11 hours outage on Sierra and counting.... Date Time Of Last Edit: 2022-12-01 08:37:40
| [2022-12-01 10:59:15] |
That is a good question. We were wondering about that. It probably has something to do with the non-streaming security definition data that was giving a faulty response or no response from Binance. We should cache that data so in case there is a problem with that data we can still continue without it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 11:49:05] |
Refer to: RESOLVED: Binance Data Feed Unavailable Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
