Date/Time: Fri, 13 Nov 2026 21:24:35 +0000
*IMPORTANT* Binanace data feed down (again)
View Count: 893
| [2022-12-01 01:06:01] |
| User486817 - Posts: 83 |
hello, the binance data feed seems to be frozen again. i reported this issue once before on 11-17-2022 and this is basically a repeat. my charts are stuck on Dec 1, 00:26 UTC. thank you. |
| [2022-12-01 02:46:23] |
| Sierra_Chart Engineering - Posts: 25422 |
This is an issue with Binance. Hopefully it will come back soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 04:26:22] |
| Amelyn - Posts: 46 |
All of my other charting platforms are working fine, how can this be an issue with Binance?
| [2022-12-01 08:41:19] |
hello, any update on this? it's now 8:40UTC and i'm still frozen... kindest regards, |
| [2022-12-01 09:32:12] |
| User251043 - Posts: 50 |
Hi, Binance not working yet. Also I can read in the forum other users are having issues with other data feed. Could you please give us a bit of info on what are you doing about these connectivity losses? The answer "Hopefully it will come back soon." is not helping us a lot... It's very very rare that lots of users are having connectivity issues on their sides at the same time. We're waiting to see if we can work today... Thanks. |
| [2022-12-01 11:00:40] |
We see that Binance resolved the problem. The data feed is available again. It definitively is an issue with Binance. That is with certainty.
| [2022-12-01 11:11:47] |
Great, thank you. Is there any way I can receive the data feed again? I'm asking for the symbols and I receive this: SC DTC Data with Market Depth | Sending symbols for exchange request. Exchange: binance_cryptocurrency.exchange.data | 2022-12-01 12:08:12.064 SC DTC Data with Market Depth | Received 0 symbols for Symbols for Exchange (binance_cryptocurrency.exchange.data) request. | 2022-12-01 12:08:12.273 The charts are not updating, and the green bar on top of the window is stuck on DF:23 ST:1, 1 BR:1282 I tried to disconnect and connect again. I closed SC and opened it again... nothing is working. What am I doing wrong? Please, help. Thanks! |
| [2022-12-01 11:16:54] |
| nasz69 - Posts: 1 |
still not working for me ..
| [2022-12-01 11:33:43] |
I read in another thread some users from Portugal are having connection issues with their DOM for some days. I'm connecting from Spain. I have 0 Binance data feed now, so if you at SC already have the data feed then the geographical hypothesis gets stronger. |
| [2022-12-01 11:39:16] |
We do see that Binance is still down. The problem is not resolved. We were mistaken. The problem is with the security definition data from Binance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-01 11:39:33
| [2022-12-01 11:49:12] |
Refer to: RESOLVED: Binance Data Feed Unavailable Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-01 12:14:26] |
Thank you for addressing this issue :)
